orginaly posted by philip on another thread
"12 is nothing. It isn't listed in the FSM.
11 no reference signal from during cranking. Crank position sensor.
24 TPS voltage high or low.
41 generator field not switching properly.
55 isn't in the manual.
Ok check the crank position sensor first. The gap should be .050". Check the voltage to the crank sensor. It should be 8 volts."
I know that you didnt need all those code but its what i could get. like stated above check the air gap in the CPS. Idk if you know where its at. so here goes its at the top of the harmonic balncer if its too far it cant read engin rpm so it wont let the alt work
hope this helps {I also hope I didnt offend you philip by quoting you off another thread}
ch
ch
