my truck wouldnt start one day so i jumped it and went to work. then the next morning it happened again. so i went to see if my my alternator was bad and he tested the battery first and it read 4.6 volts. so i got a new battery but then got drained to 6.6 volts. then i put the new alternator on
and i was told that doing that fries the alt which it did. so then i charged the battery up to 12.6 volt and a hand held trickle charger my dad uses to charge are trailer battery.
then i put another new alt and it fried that one. so i went out and got a brand new battery and a brand new alt and started the truck and it only read 12volts still. i checked all the fuses there's no draw there. i cleaned the engine block ground for the battery and cleaned it. the only thing i havent done is a voltage drop check. and that would mean that the alternator's wiring is messed up right?
i also bought an external voltage regulator. people on here said its my PCM because there's a a built in voltage regulator in it. so installing an external regulator would bypass it. so i think im gonna do that tomorrow morning.
also i fixed a fusible link before all this happend. i pulled on all of them and none of them stretch can they pop but the rubber stiffen up again?
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Cummins Diesel Forum
A forum community dedicated to all things Cummins Diesel! Originally founded for owners and enthusiasts of Cummins powered Dodge pickups, the Cummins Forum has expanded to include ALL Cummins Engine applications! Come join the discussion about reviews, drivetrain swaps, turbos, modifications, classifieds, builds, troubleshooting, maintenance, and more!
