no spring compressor.... you will just need to remove the bolt from the bottom of the shocks...( will go thru the frame) there is a hole just big enough for your socket to run thru to get to the bolt. remove that and then you will need to remove the 3 bolts from the tower on the top of the shock and the tower will come right out up thru the springs.. then you will need to remove the nut from the top of the shock and seperate the shock from the tower. then reinsert shock into coils and put bolt in bottom of shock and tighten down... then put the tower on the shock and then compress down and put the 3 nuts back on the tower and do the same for the opposite side.
Note: it may be easier to remove the tower from the drivers side before you try and pull the shock and all out
