What are some good brands of axle lube to go with?Also do they have gaskets or do you just permatex the cover back on & to what torque spec? I've never changed axle lube before,but it seems to be fairly simple.Any steps or tips at all would be appreciated.Thanks guys!
Crayola spokesperson
take the cover off...spary it out with brake clean inspect the gears and carrier make sure everything looks good clean the gasket surface but i nice bead of black silicone on the cover slap it on tourque it down...im running amsoil 75-140 synthetic severe gear..its easy man:thumbsup:
Rescue Tower
You should drive it a bit before pulling it. Helps with the drain if the oil is warm.
Mopar1973Man.Com
I just use standard ol' clear silicone sealer.
I run the truck at highway speeds for 15-30 miles get it nice and hot and pull the covers off. Let then drain as much as you can. Then using a rag wipe the bottom out looking for metal debris and get the last bit of gear lubr out.
Clean both faces. Put a bead of silicone sealer down on the cover and bolt it up. I use a air ratchet so I don't bother to check torque it tight... Then I fill the diff up with 80W-90 gear lube and fill it it till it running out the hole. So next time I check the fluid it should run out the hole...
143K miles and stil no problem with my axles. I change the fluid every 30K miles.
I just did this two days ago for the first time. I used mopar 75-90 outta paranoia. Super easy. warm up with a drive drain srpay with brake kleen or a generic brand, clean yer check plug, ensure gaskets are in good shape, put er all back together filler up, spray the outside w/ brake kleen to be sure it is dry and free of oil, go for a boot and check for leaks. it's about 4 ltrs in the rear and about 3 ltrs in the front. good luck don't be scared.
