Double check your shims and make sure they are pushed in all the way.:confused013: I had one that wasn't in all the way and it gave me grief...:doh:
Check your sims while your at it.:hehe:Double check your shims and make sure they are pushed in all the way.:confused013: I had one that wasn't in all the way and it gave me grief...:doh:
OverTemp codes come from the H&S SIMS. That is by design.i didn't do the pressure sim i just took the hose and looped it so no dirt can get in. I just rechecked all the sim connections and put some elctrical connections grease in each one still get the CEL. They are over temp sensors. I dont think they are bad but would just like to get them to stay off. They stay deleted for about a minute.
:agree2::agree2:Don't loop the pressure sensor tubes together. They must be left open.
The edge will not clear the codes for overtemp sims. The CEL will return after warm up. If it is bothering you then check with James at RSD and get a set of the 330 ohm Shibby SIMS. Good price. :thumbsup:could it be a possibility that my sims are bad or something? cause the edge will clear but they come back would think that once there cleared they should stay away but the computer is telling it different?? idk im confused
sorry to hijack your thread, but i read the new EGT sim basics but i am still wondering the same thing i think. I understand with the 330ohm will go to regen is that with just the sims and no pressure box sim or does that not matter
No you won't.will i go into a regen and then to a limp mode with these sims?
