1 - 4 of 4 Posts
I went to start up my truck tonight after sitting since yesterday and the CEL light came on right after it turned over. I did the key thing to read the codes and it was P2509 - ECM/PCM Power Input Signal Intermittent. What should I do? Is it a battery issue, connection to the ECM? It rained really hard here last night, could that be part of it? Thanks for the help
Russ
did you have your batteries go dead or disconnected or maybe a loose battery cable. I had that code before it went away with no issues i checked the connections at the batteries
No they havent died or been disconnected. And all the connections to them look fine and are tight. I just tried it again and the light is still on, but the code doesn't show up.
1 - 4 of 4 Posts
