I have my cb down in between my driver an middle seat and my antenna is mounted at the front of the bed on the drivers side.
:agree2:The antenna is what really makes or breaks a setup. You can have the best radio out there and a cheap antenna and you won't be able to reach out and touch or be satisfied. A CB that hasn't been peaked and tuned or is just off the shelf will still get good range with a decent antenna. The 102" whip is about $20 at radio shack and can't be beat for the price. The only problem is it's so long. The wilson 5000 roof mount is an awesome antenna and if you need a mag mount I'd go with the Wilson 5000 Mag mount. All this gets addicting. Next you'll be looking for linear amp's. Good luck.
Hey TX![]()
Nothing special. $35 Cobra, and a $50 antenna from Frys. I'll use it to talk to truckers when I need to find out whats going on with the road ahead of me, but mainly use it to talk to my buddys when we are offroading. Makes things A LOT easier than rolling down the window and yelling. All in all it is a really good investment, and the CB never gets in my way.
Mine is wired straight into the bottom 12v source.
I was talking about the Elec brake controller. normally it would be mounted where your radio is or in a similar mannerIt is a Cobra.. It works fine so far 2 years later. With the whip on her we have gotten about 5miles apart.
It's when you get a bone stock CB and the tech goes and bumps up the wattage and tunes it for a jumper/linear. You can get a cobra 29 and put a talk back relay in it and a moss fit final and have just as much radio as a General Lee or Connex 3300 but you won't have as many channels. When you run a linear you have to run the CB on low and it should be around 2-3 watts dead key. My General Lee barefoot on high is around 80 watts and with the Texas Star 250 it's close to 275watts if not a little more. That means it will get out 10 or so miles and sometimes 20miles.whats "peaked & tuned" mean? i never new there was so much involved with a CB. I thought you just hook it up & away you go.
Great info on CB`s, keep it up guys.
