1 - 3 of 3 Posts
Does anyone know how to clear this overhead alarm? I had my XRT stollen a couple weeks ago so i can't clear it with the programmer. I guess my question is do i need to take it to the dealer to have it cleared.
It depends; My truck had the same problem and required an update to the ECM. If your DPF is full you could drive it on the freeway for 50 minutes at 75 miles an hour and that should fix it.
Since you have an XRT I assume you're deleted, so the message shouldn't be popping up? I believe H&S said this was fixed in a newer firmware, but...since you don't have the XRT... :confused013: Sucks that it was stolen. :(
1 - 3 of 3 Posts
