will it lower my EGT temps to remove the cat and scrubber? or do they make much diff.
Volcom18 · Registered Joined Feb 11, 2008 · 1,442 Posts #2 · Feb 3, 2010 Only show this user dpf and egr deletes will lower your temps quite a bit.
-lenny- · Premium Member Joined Sep 14, 2006 · 6,894 Posts #3 · Feb 3, 2010 Only show this user Will also help your mpg and extend engine oil life.
M mrktl29 · Registered Joined Jun 11, 2009 · 12 Posts Discussion Starter · #4 · Feb 3, 2010 Only show this user have done the egr and dpf deletes, but have done those, but when on level 3,4 ,5 on my edge egt temps still sky rocket, hit 1350 and edge alarms
08stroker250 · Registered Joined Mar 27, 2009 · 954 Posts #5 · Feb 3, 2010 Only show this user Set your alarms to go off at a higher temp. You can hit 1600-1700 in short burst. Just don't want to hold it there for more than 10 seconds.
SkinInc69 · Braaap, Braaap, BOOM!!! Joined Aug 24, 2007 · 6,917 Posts #6 · Feb 3, 2010 Only show this user Delete your EGR aswell for huge EGT drops!
M mrktl29 · Registered Joined Jun 11, 2009 · 12 Posts Discussion Starter · #7 · Feb 3, 2010 Only show this user cat have done the egr delete, will it help to take out the cat?
Volcom18 · Registered Joined Feb 11, 2008 · 1,442 Posts #8 · Feb 3, 2010 Only show this user It will help, but it won't be a dramatic drop in egts. Just fyi, Edge runs hotter than Smarty and H&S products.
