1 - 20 of 35 Posts
I finally got my truck back and I am loving it! It is a 2013 CCSB 2500 4x4 G56. I had the Carli Commuter 2.0 installed with the torsion sway bar, fox shocks, rear add a packs, high clearance control arms, synergy steering linkage, Readhead Steering Gears steering box and a Fox steering stabilizer. It steers great and rides even better going down the road! Well worth the investment!! Also i had a previous vibration that ended up being a bent drive shaft. Up next will be wheels (not sure which but will be 18's and bronze) tires (Nitto Ridge Grapplers 35 or 37's not sure exactly) and Amp Research Power XL side steps!
Discussion Starter · #2 ·
A few more pics
haha yeah that is what I was thinking but I am still not sure about it. I don't want to have to regear or risk damaging any gears or the transmission. Then it creates another question of staying with 18's and doing 37's or doing 20's and 37's haha. oh the problems I have created. You guys at CJC Offroad have been great with answering all of my questions and helping me with my build!!
Wait what!? I have a 1st gear???? hahahaha
haha so on a 18x9 do i run a 37x11.5?
don't go any size on 20's. tires are more money and ride like a$$. go with the 37's, its like having a 4.10 auto setup. also, I thought 2013 2500 had the newer front end with the radius arms? also, my fox/carli had a spacer on the shock tower, just curious why yours doesn't?
ahhhh, i thought it was the other way around.
i know this might be hard to differentiate, but how big of a difference would you say the rear add a packs made in the ride? im also running fox 2.0
Discussion Starter · #14 ·
@str8t six They help keep the rear feel more planted and alot less hopping around. Well worth the money. I'll be running 18's and Nitto Ridge Grappler 37's. I just need to find some bronze wheels I like and then decide if i want to run 37x12.5 or 37x 11.5. The wheels will be an 18x9
Reactions: str8t six
run the 13.5's. my 12.5 look too narrow IMO
Discussion Starter · #16 ·
i don't want to go that wide.
Im in the market for bronze wheels too! We need to start a bronze only thread haha. I am wanting to go with 17's on 37's, just trying to figure out the offset/bs issues.
Are the high clearance arms a must for 37's? I dont have them on my Carli 2.0 kit, as I just have 35's right now, but when I make the switch I am curious about those and if I need them or not. And re-gearing since I have the weak 68rfe 3.42's
Reactions: jyandrick01
Just put on 37's on 17's here. You will need +18mm or more offset unless you start to gut the fenders. My wheels are +18mm (5.450" backspacing). Glad someone else had an add-apack - I added 1" block + the add-a-pack to get the proper rake.
If you're unsure on 37x12.50's get 35x12.50's for peace of mind. Only 1.5" difference overall. I'm going to run a set of these 37's then see if I want to go back smaller next around
Looks good! Do you have any pics down the side, to show the offset? I have +12 (5.5bs) now and they stick out quite a bit more than I expected. I am currently on 35x12.5's as well and they only ever measured to 34 at most, now at 33..
1 - 20 of 35 Posts
