It's been so busy lately with working on the truck, working, and getting ready for Christmas — it's been hard to find the time to make the posts!
Putting the steering stabilizer bracket in is pretty simple. I wasn't able to slide the factory stabilizer into the bracket while on the truck.
Pulled out the stabilizer (easy) to see why it wasn't fitting. The sleeve in the stabilizer is a little bit larger than the opening in the bracket.
Few minutes with a file on both sides of the stabilizer sleeve and it fit.
I did ask Carli about this and they basically said that the bracket is designed for the tolerances of their stabilizer setup.
So, just an FYI, be prepared to have to file a little bit off your stabilizer.
Next is the track bar. Beast of a unit.
If they offered these already set up to the correct length of 39-1/8" for a nominal fee, I'd probably pay it just to not have to worry setting it up correctly.
It's not impossible or anything, it's just one of things that gets in your head like "I HAVE to get this right, and there's Red LocTite in there, so I can't mess it up!"
But, it's doable, and you do have a bit of time. A pair of 24" adjustable wrenches (Crescent Wrenches) from Harbor freight work wonders.
Just showing how stout it is.
The silver "ring" in the center of the hole is the untouched inner wall of the tube. It's thicc.
Set it up in the bench vice, swiveled so you can use the bench top.
I just stood up on top of my bench with the wrenches once I had the length dialed in and the LocTite applied.
One 24" wrench holding the joint, one wrench turning the nut.
Note: I did NOT have the misalignment spacers in the heim joint when actually tightening it.
As mentioned above, a cargo straps is one of the options to pull your axle in the direction needed to line up that frame hole.
Axle side bolt first, then frame side.
If the axle is on jack stands, I would suggest lifting it up with a jack under it so that it's able to move freely side-to-side while you do this.
