hum... im guessing fender and bumper trimming..:confused013: i will have to check that out.Search for the "Stock with big meat" article. There is a guy running stock suspension and stock wheels with 37s Goodyears. he says no rubbing except on the upper control arm at full lock.
This may be true. I know the KORE has different intentions with their suspension (IE washboard roads, baja, etc.)ok well what if i put skyjacker coil springs on?? i was told they would lift it up 2" more then the kore ones...is that true??
Stock wheels could give him rubbing on the control arms, the H2's I have move the tire out about an inch but then you're REAL close at the fenders, my 35's rub on my mud flaps.I would think with stock wheels, your BS would save you from rubbing control arm. I can't vouch for fender though
