1 - 16 of 16 Posts
· Cummins CrAzY
Yes you can run 285's on a stock wheel.
Hold up I have a 4x4 chevy duramax that has 285's and dodge's have way more clearance than chevy u can prolly even run a 305.
got 'em on my 99. all stock rig no rub.
they fit fine. Damn near every other person on here has them. Mine fit fine on the stock rim at stock height. With the 2" leveling kit I'm pretty sure I can clear 35's.
ive got 285's on stock wheels now, used to have 35's on but you'll need a leveling kit for that
I have 285's on my truck and my buddy had 305's on his and both of our trucks are stock height and no problems for either one of us. :thumbsup:
They will fit easy no need to worry guy. I run 315/75/16 with only a leveling kit.
my 305's fit the wheel fine, just rub a little on the C.A. when fully cranked
285's are generally a slight bit cheaper because they are a bit more common and not as much material. 305's give it a slightly bulkier look, and 285's appear a little bit taller. actual height is generally within 1/2" from brand-brand.
My 305s fit fine with the stock 8" rims, no rubbing.:thumbsup:
1 - 16 of 16 Posts
