the obdII plug might not have been seated all the way or had a good connection. Mine has done it a few times with the smarty and my powerpup.
Yep move programs all you want no need to return to stock. Promise! :headbang:So if youre useing the S67ME version 8 and want to go to 10. Just download the 10 version to the Smarty and load into youre truck and everything is OK????:confused013::confused013:
because your door was open. if you close it and do it again it wont give you that error:thumbsup:Went to return the truck to stock so could go from the 10ME to the 8ME. When i tried to return the truck to stock it gave me a can bus error on the Smarty.
I tried it again and everything went ok!
Any reason for this happening???? Is it just something that happens on occasion or should i be getting it looked at??
Glad you are up and running bro :thumbsup:Door wasn't open. In fact, i touched nothing! I hit the right arrow key after getting the error and tried loading again. All went fine the second time!
