1 - 2 of 2 Posts
is there anyway to change it without removing the VP44 and if so whats the bolt size on it?:banghead:
I did mine a month ago, Mines an 01 ,i did not remove the vp44. It was very cold in Chicago outside on my driveway! I used a 1/4 inch ratchet with a t-27 torx bit if i recall. Lay under your bumper facing up, hook your left arm around the top of the vacum-pump and work the ratchet. Your right arm can assist to line up the ratchet on the engine block side. Take your time ,dont get frustrated , you will get it.:thumbsup:
1 - 2 of 2 Posts
