1 - 20 of 43 Posts
what kind of benefits would i possibly see by swapping out the cam in my truck ? i'm getting a set of 90hp nozzles a new turbo and a few other fuel related enhancements just curious what i might get out of a cam change if i decide to do it down the road
quik spool run cool better mpg smoother idle
All is true but the mileage. No one here that I seen can back up any mileage gains. Thats why I haven't done.
any recomendations as far as who's cam to run ?
Northern CA Chapter President
hamilton big stick
I assume a cam would help a larger single turbo with towing (ie: quicker spool and lower egts).
looks like a good thread!! lol
Im about to order a Hamilton Big stick cam :party018:
Where is a good place to buy a Hamilton cam for my 06?
Discussion Starter #14
back to the top looking for some more input
Discussion Starter #15
:confused013: well i guess this thread has bit the dust
Cam can be helpful for a large singel but are not needed till you have maxed every other option out, ie twins, big stix. Cams are more for that guys trying to squeeze out that last HP. So if you planning over 800hp add one. If you going to be in that area of the engine-go for it, but if you just doing it to add, save up for twins.
I second that motion. You can make a lot more impact for a lot less in other areas.
Discussion Starter #18
friday evening bump :headbang: johnny 5 needs more input
Discussion Starter #19
any thoughts on the maxspool II ?
HAMILTON!!! not maxspool
1 - 20 of 43 Posts
