1 - 3 of 3 Posts
hi,
i bought this truck with the mod already done... has the cable operated front locking hubs for the 4x4, anyways, needing to know how it works,does it lock when i push it forward,or when i pull it towards the back of the truck?
p.s. what operates the 4x4 light? mines stays on,the transfer case is in 2wd mode.thanks alot
The CAD (Central axle disconnect) Is located on the back side to the Right of center of your front axle, It is originally operated by vaccum, The cable connects to it, When you pull it out it is locked. There is also a detent switch (wire hooked up to it) right there on the plate, It's been a while since I installed one, I was thinking it was adjustable but I am pretty sure it's not, anywho that switch is what turns on the 4x4 light. You might just unscrew the switch and see if it is gunked up or something.
Alright ill check that out,thanks for your info
1 - 3 of 3 Posts
