I need new cab mount bushings (really only need the one for passenger side rear). Every set I find seems to stop at 1985-will those kits fit our trucks or does someone know where to find the correct setup for these trucks?
Thank you
Thanks-I will order and see what happens!
I just did the cab bushings on my 84 Crewcab. Exact same bushings as the ones I pulled form the Clubcab 93 donor.
About the only ones available are the Poly bushings. I couldn't find any OEM rubber ones.
How harsh are the poly bushings with the cummins? Im in the market for rubber bushings too but can't find anything
Well the bushings I removed from my crewcab had already been replaced with the poly ones. I had been driving the crewcab for 3 years with them in place.
But to be honest it would have been hard to notice any additional vibrations, or noise, since I had no interior carpets, headliner or moldings to absorb sounds etc.
I would prefer to have rubber if I could find them...but I have to use what is available.
