I have a few questions for you guys and I hope I am in the correct forum. First off I am considering purchasing a used cummins, from 04.5 to 07, with precedence toward the 06-07 trucks. I also want a G56 and quad or mega cab 4x4. As you all know it is becoming hard to find good 5.9 manuals and it is even harder to find one near my loacation. The goal is to determine whether or not this is practical for me at the moment, as the trucks I am finding are >50,000 miles, mostly around 70,000 and would possibly need some work in the future. So I have a few questions:
1. What have you all typically done as far as finding trucks 200-300 miles or greater from where you live, in respect to looking the truck over and what not, making multiple trips, and did you negotiate over the phone before traveling. Also to add I will most likely have a trade, my current 1500. So for those of you that have traded, did you attempt negotiations over the phone prior to taking the trade to the dealer.
2. I have been compiling a list of things to inspect for when looking the truck over that are diesel/ cummins specific, I have others that are for a used vehicle in general but wont bore you with that. So we have: check 4th injector line for wear, watch a cold start and check for smoke, hard start, and rough idle. Also after driving the truck and reaching opperating check for blow by using the oil cap. I also want to check for signs of a pressure box such as a mp8 but am unsure of what to look for so I'll have to research that some more. Also just looking at what if any modifications that have been done. I also intend to look for evidence of a gooseneck/ fifth wheel, I wouldn't overlook a truck that has either of the two, I would jsut prefer one that doesn't and would use it to my benefit. However I have noticed a high number of truck from that age that do have a trailer brake harness, is this something that you would stray away from, approach with caution? Also if I am forgetting something please feel free to add.
3. I am mostly trying to determine what kind of costs that I could be in for if I decide to go this route, so I have created a list of things I could be looking at in the near future post purcahse. First is the injectors, looking at ~$400 a piece and I dont like the idea of remans, but it looks like thats my only option if I want the 124 degree, I'm not sold on the 143 yet with the 04.5-07 piston, and totally confused about going with the SAC over the VCO. I have been looking at the carli or thuren track bar to replace the worn stocker, then you have ball joints, tie rod ends and others will be considering the usuals like moog ( I heard their quality wasn't the best anymore) and also Carli. I would also be looking at adding additional filtration but am undecided on the best route for that.
Thanks for taking the time to respond, I have been researching for a while and feel like i am on the right track but would like to verify a little so that I dont Know the incorrect knowledge so to speak. Also I feel like I probably forgot to add some things, but anyways, thanks again.
