Pulled the turbo and exaust manifold and the 5th exaust port are oily and wet,no coolant in there,just oily as heck..
can any one help??? i started a thread and got no response...are there any diesel mechanics here??? need help fella's???
Time to pull the head and inspect the damage to #5 suspect bad/broken rings and possible cylinder wall and piston damage.
Likely due to fouled injector, how many miles and fuel filteration set up?
X2, tear it down- inspection time.
You can do a monameter test and pressure differancal tests first to see if it's with the head or pistons/cylinders.
