push the brake hard and push the throttle at the same time.How do you build boost at the starting line for a race. I see all automatics doing it at the starting line.
Yep that is pretty much it. I would not do it on a stock input shaft or if you did I would not go over 5-10 psi...push the brake hard and push the throttle at the same time.
good call husky..should have added that.. ive even heard of stock flexplates twisting in pieces too. boosted launches "should" be left to the guys with "billet" goodies in there signature and a padded bill-foldYep that is pretty much it. I would not do it on a stock input shaft or if you did I would not go over 5-10 psi...
