Hello guys,
As the title says I am wanting to build my early 2004 for a healthy tow rig. The goal is 550hp, limited by organic dual disc clutch and stock cp3, that will spool up quick for towing but still has enough upper end for some weekend cruising, all while avoiding high EGTs. I just pulled the engine because of bad injector and broken rings on #6. Looking to get it to the machine shop soon.
Already have
-ARP Head studs
-Air dog lift pump (150?)
-Smarty Pod S06
Build list
-o-ring head (and other needed machine work)
-Industrial Injection 60hp injectors
-Hamilton 178/208 cam/pushrods/103#springs/tappets
-AFE 5" SS exhaust
-AFE Bladerunner or ATS arcflow intake horn
-ARP rod bolts
-Fleece fuel filter delete
-Fleece coolant bypass kit
Now for the turbo, I am really considering the ats 3000/5000 compounds. Has anyone had experience with these turbos? Have also looked at crazy carl compounds which is slightly cheaper, has anyone had experience with this set up? Which BW turbos do you think would work best for what I am looking for? If not compounds what single turbo do you think would fill the gap?
Also plan on having a tuner put it on a dyno after I do all this work to really dial it in. I am sure that 550hp is a modest number for the parts I am considering but would rather detune to 550 than not reach my goal.
Do you guys think anything on my list is out of place or am I missing something?
Thanks for input
Already have
-ARP Head studs
-Smarty Pod S06
Build list
-AFE 5" SS exhaust
-ARP rod bolts
Thanks for input
