Ok so I'm finally going to start my build. Im shooting for about 550 right now until i can get twins but thats later. The list i came up with is so:
5x14 SDX
62/68 E.D.
Fire ringed and studed
SB DD with upgrade shaft
4k Gov
No plate/Mack plug
Guess thats most of it. The only thing im not sure of is what order to do these since i cant buy it all at once. Looking for your guys opinions as to what to do in what order. Im thinking the gov springs and injectors first and i can tune it down if necessary until i get a clutch. Then after the clutch Im going to get it fire ringed and studded and have the valve springs installed and while the head is off and get it timed while its at the shop. Then the turbo will top things off for now. What you think? And as a side note, what timing do you recommend? Im thinking around 18? All input is appreciated.
