Hello. My dad has entrusted me to mod his pickup. He told me he is looking for around 500hp but not a set number. The truck is in my sig. He does tow a travel trailer but that is few and far between. He wants a reliable setup for a daily driver without the depletable power adders like meth, nitrous, propane, etc. His budget is pretty open ended but does not want to jump the gun on spendy items without knowledgable feedback and a plan of action. Here is a list I put together from reading countless threads on here.
Gauges (some come with programmer) w/fuel pressure (not just some light, but an actual gauge with a needle)
Lift pump (your choice) at least 150gph
Air Filter and intake (your choice)
Free flowing exhaust (4" dp is standard, 5" minimum for rest of system)(your choice)
Torque converter (your choice)
Valve body (your choice)
BD power super B Twins
Head Studs (minimum) possible o-ring above 50lbs.
150hp injectors at least
programmer with 100hp-120hp
Granted the gauges could be replaced by some programmers, and the air filter by the tow twins. These are in no particular order, just a general list. Granted a full trans build and the twins are the spendy items, hence the plan first.
Thanks in advance,
Justice
Thanks in advance,
Justice
