had lots of fun trying to get my KSB off to install my timing spacer, ended up breaking it at the rear bolt hole. the hunt for a new one begins any ideas?
classifieds? Someone may be parting out an injection pump.
I'm starting to wonder if mine is working.
also i guess my KSB is hot wired from what i read...i hooked my shutdown solinoid to 12v power on a switch a few years ago and also added a pull cable(the only way to shut my truck off now), but i guess the KSB and SDS run off the same wire...so what does my KSB do if it always gets 12v?
Purepowerdiesel.com has the KSB listed for sale.
I dont know, but i've heard its hard on the pump to leave it hot-wired because it closes off the bleed port of the pump's internal pressure regulator and internal pressure increases.
im not sure if if it is? im still learning about all this KSB stuff, so with 12v to it thats "hot wired"? and that adds timing?
well you cant buy a new housing, just the whole KSB...$650 from a Bosch dealer and dodge and cummins both just sell the sensor, i guess wielding it back together is my only way out of this mess
Discussion Starter #8
i got it all back together and on a toggle switch, KSB on drops RPM about 400 at any throttle setting and the truck has a much rasp'er exhaust not...i couldnt get a good butt dyno reading since the roads are bad...sideways in 5th gear is no good in slush
