1 - 3 of 3 Posts
I changed the crank sensor. Reset codes with smarty. Started engine, it threw the 336 code again almost instantly. Truck is running so rough, I don't even dare to let it idle.
I then unplugged connector cleaned and plugged it in again. What am I doing wrong? Is there a certain way to install this sensor, other than just put it in?
Does anyone know what voltages I should I have on what pins; so I can verify wiring?
This is my only vehicle. Need help.
Thanks
Discussion Starter #2
Bump, any one.
Really can't figure this out
Bump.
Compared voltages on cam sensor connector and crank sensor in key on position they match each other so I guess that's right?
Can anyone help??
1 - 3 of 3 Posts
