21 - 33 of 33 Posts
Seems that powder coating the aluminum while good for looks, reduces the efficiency some? I do know there are options you can do with powder coating to improve the heat transfer, did you do any thing like that?
Vendor
Discussion Starter · #23 ·
Im local to yalls do you rent out the dyno for runs?
Sent from my DROIDX using Tapatalk 2
Hey Bubba! Our DynoJet is currently being used for internal testing purposes only. I will surely contact you if this changes. I believe we have been in contact before regarding test fits on your truck? Sending a PM your way!
Thanks
Excellent question! Our engineers were also interested in this theory and decided to perform some testing to provide real life data(We are all about any project requiring dyno use!). We performed a test with our new J-Line intercooler using both a painted and unpainted core to determine any differences in power, pressure, and temperature. Keep in mind this will vary slightly depending upon the vehicle, intercooler, exact coating material, etc. but provides a reasonably accurate comparison.
This report is also available in PDF format if you need to zoom in to view our charts!
Link
Thanks :party018:
World Champs!!!
I don't think I've ever seen a company back up their statements with actual test data...
Thanks for the data. Good to know the amount of engineering you put into the product.
Yeah, these guys have it going on for sure.
When they were doing fitments and designs on my truck they had the laptops out with the CAD software designing and flow testing the designs through the software.
It was impressive to say the least.
Vendor
Discussion Starter · #27 ·
Thanks guys! :)
Thanks!
Check back tomorrow for our Cummins intercooler installation video!
I no y'all have done the testing. But is the intercooler avaliable in polished end tanks?
Vendor
Discussion Starter · #30 ·
:agree2: I'm impressed.
Thanks!
The intercooler will only be available with a black or silver powdercoat finish at this time.
Thanks
As promised we have the installation video for the Mishimoto Cummins Intercooler and Piping Kit available for your viewing pleasure. Enjoy!
Thanks :party018:
Vendor
Discussion Starter · #31 ·
Hey guys,
Today is the official launch of our diesel product line! You can view all of our Cummins cooling products by clicking the image or link below!
Dodge Cummins Performance Parts
Check out our Intercooler Pipe and Boot Kit for the 2003-2007 5.9L!
This includes our signature Mishimoto Constant Tension T-bolt Clamps. :shock:
Feel free to ask any specific product related questions. I would be happy to help!
Thanks
John Marsteller
Vendor
Discussion Starter · #33 ·
Today we will introduce these new products to the community and provide an application listing of our current offerings! Each specific application is linked directly to that product page which will provide more information, images, tech specs, and videos.
Performance Intercoolers
• Bar-and-plate core
• Durable cast end tanks
• Engineered for maximum flow and reduced pressure loss
• Lowers EGTs and intake temperatures
• Supports substantial boost pressure
• Available in black or silver
• Direct bolt-on fitment
Applications
2003-2009 Dodge 5.9L/6.7L Cummins
Intercooler Pipe and Boot Kits with DuraCore™ Technology
• Aluminum pipes made in the USA
• Engineered to eliminate restrictive bends in factory piping
• DuraCore™ technology withstands higher air-charge temperatures and pressure
• Decreases pressure drop and increases power
• Aluminum and silicone construction for improved reliability
• Perfect supporting modification for high boost and/or larger turbochargers
Applications
2003-2007 Dodge 5.9L Cummins Intercooler Pipe and Boot Kit
2007.5-2009 Dodge 6.7L Cummins Intercooler Pipe and Boot Kit
Factory-Fit Boot Kits with DuraCore™ Technology
• Designed as a direct fit with factory intercooler and piping
• DuraCore™ Technology resists degradation from oil, fuel, and heat
• Manufactured with silicone and heat-resistant embedded fibers
• Increased pressure tolerance for high-boost applications
Applications
1994-2002 Dodge 5.9L Cummins
2007-2009 Dodge 6.7L Cummins
Aluminum Radiators
• 100% aluminum construction
• Brazed aluminum core
• Increased fluid capacity for improved efficiency
• Maintains factory fitment
• Improves heat dissipation
• Superior durability and reliability
Applications
Silicone Coolant Hose Kits
• 100% silicone construction
• Heat-resistant embedded fibers
• Direct fit
• Available in black, blue, and red
• Increased pressure and temperature tolerance
Applications
1994-1997 Dodge 5.9L Cummins
1998.5-2002 Dodge 5.9L Cummins
2003-2010 Dodge 5.9L/6.7L Cummins
Intercooler Kits
• Includes intercooler, piping, and DuraCore™ boots
• Combination of the intercooler and piping maximizes cooling efficiency and power gains
• Optimizes airflow for reduced pressure loss and lower intake temperatures
Applications
Feel free to follow up with any specific questions!
Thanks!
21 - 33 of 33 Posts
