I'd have to check, but the bleeder screw should be on the top, should be a left and right caliper, and it sounds like you have them mixed upwhen i put the calipers in, they were dry. the zert is at the bottom of the caliper so when the fluid is pumpmed in through the middle of the caliper. it left air pockets at the top. i took them off flipped them up side down so the zert was at the top then bleed them tell the plungers moved out and pushed them back in with the zert open while maintaing pressure tightened it. put it all back together and worked like new.
04.5 2500slt, auto 4x4 on demand
