I have noticed that my brake lights and controller come on randomly when parked. I have only noticed it happening while its parked and not running. It happens both with the keys in the ignition or not. Today I noticed it and went to check it out. Didn't change anything when I pressed on the brake nor when I started it and braked numerous times. They stays on for some random amount of time than shut off. Any ideas???
brake switch adjustment, pedal hanging, or brake switch bad.
I have an update and still need help. I replaced the brake switch and it didn't help. I got home from a drive today and they were still on. I decided to pull the fuse and save my batteries. I pulled the fuse in the engine compartment and they did not go out. A couple minutes later they went off on thier own. For the hell of it I put the fuse back in and they lights worked as they should. I pulled the same fuse and they didn't work. So what would cause the lights to still work even though the fuse is pulled? Is there a ground short?
