go to the vac line coming out of the vac pump. you will see a T in the line, with a smaller line going UP to the ledge of the firewall. Break that line in half.
Blow (with your mouth) into the line that you cut and you will find your leak real quick. youll hear the leak hiss as you blow into the line. When you find the leak, mend the plastic line with a small piece of rubber vac hose and youre good to go.
on my truck, the brake/abs light JUST came back on, and i found/fixed the leak and the lite is still on. I think the little pressure switch fried itself, but the only way to know for sure is to get a vacuum guage and check to see if its actually getting the proper vacuum. contrary to the one of the posts above, taking the wiring plug OFF of the vacuum switch actually turns OFF my brake light...
