i have a 2nd gen 24 valve but my abs and brake lights pop on when i start driving, then will stay off for a few days and pop back on again. it is becoming more frequent, would anyone know what is going on?? didnt mean to hijack your thread sorry....
bump anyone got any suggestions??
My 99 has had the break and abs lights on for a couple years ... would like to know myself ... also my speedometer doesn't work until I hit 83 mph.
abs sensor could be going out, wiring, lots of things could be the cause and could be a simple fix as your brake fluid is dirty an needs to be flushed
Esjayco- if you look on your rear diff i believe there should be a sensor on the top side of it, if there is take it out that is your abs sensor may be no good anymore and causing your light as well as the problem with your speedo
