Truck has a billet built trans by TRE performance in VA, anyhow, I want to install a TC lock up switch, any threads on how to go about doing this? I wasn't sure if because its a built tranny and it wasn't done at the time it was all done if it was still the same as doing a lock up switch on a stock truck?
It should work. All it does is tap into the stock electronic control
It does work, I did it and it works perfect. Just watch how much you use it tho its pretty hard on the trans.
awesome, looks great I'm going to do it tomorrow, only thing i couldnt find is what gauge wire should i purchase to run from the tap to the physical switch?
