ok so i have had the truck since new, had 100011 milkes when i put the edge comp drag on it, why am i still only makin 21 lbs of boost??? wastegate maybe?? help!!!!
correct....sorry didn't realize you had the auto! I believe the auto's have the hard line.....:thumbsupNo you need a J-hook.
how exactly do you "set it?" I have the brass elbow installed but didn't know you were supposed to do anything else. my Attitude reads about 21 at WOT.yea, it is the wastegate! I thought edge sent the boost elbow with the box but ain't sure! I would install the boost elbow and set it to open around 30 or so.....anything past 40 is putting the turbo on borrowed time. I would just plug it and watch ur guage.....JMO!!
what exactly is a j hook and where do you get one. thanks EDcorrect....sorry didn't realize you had the auto! I believe the auto's have the hard line.....:thumbsup
a j hook is a bracket with a spring that mounts on youre turbo. The spring holds the wastegate closed. I am getting 37 PSI @ WOT with my comp box on 5x5.what exactly is a j hook and where do you get one. thanks ED
You can set it by adjusting the allen head set screw that is on the 90 of that elbow....screw in and that gives you higher pressure.....it closes the gap so that the wastegate doesn't open so soon.....adjust it back out and that relieves the pressure letting the wastegate open sooner!ow exactly do you "set it?" I have the brass elbow installed but didn't know you were supposed to do anything else. my Attitude reads about 21 at WOT.
I have a hx35 turbo with an elbow and a tube to the wastgate the j hook goes on the wastegate lever???a j hook is a bracket with a spring that mounts on youre turbo. The spring holds the wastegate closed. I am getting 37 PSI @ WOT with my comp box on 5x5.
You can get a J hook from tstproducts. :thumbsup
sweet! thanks TheNatural31. I wonder why they don't explain that in the Edge instructions. it just said to install it. I hope this gives me that low-end power I've been looking for.Thanks FordKiller, i did't get to it on time!
h
I assume the automatics do not have the pressure sensing boost controlIf you have the HX-35 with the elbow then you do not need the j-hook!!
