boost ???
818 Views 10 Replies 8 Participants Last post by  jkidd
how much is too much boost. Right now Ive got a stock turbo and I see 30+ psi and in the near future in lookin into gettin a htt 64/71/14 or a bd super b special and what I want to know is how much boost well stock head studs handle??
1 - 11 of 11 Posts
40-45 psi. I blew mine at 50.
mine went at 45psi
if you reg. it at 40-45 and don't beat on it everyday you should be fine :thumbsup
how much are new head studs?
mine went at 45psi
wut do you mean by reg. tightening the bolt on the wastegate of the stock turbo??
no...leave your stocker at 30psi
for a after market turbo is what i was talking about :thumbsup
i thought the stocker wasegate was 20psi
Boost elbow/boost fooler allows you to exceed this...:w:
I would check and make sure what block you have before you do anything to it. Its not worth spending money on the turbos if the block is sh**.
anything over 35 psi on a hx35 is just hotter air. boost is not power it is a restriction. Mass of air = power. colder air=more power. pressured cold air is what you want. I occasionally get to 45lbs.
Studs are about $440 and require several re torques to maintain integrity.
1 - 11 of 11 Posts
