1 - 9 of 9 Posts
What boost # should I be seeing using the Edge? Right now I only see 25 max then it will drop to 24. This may be right I guess I am use to my old 5.9 hitting 43.
Seeing 36 - 38....running it with mp-8. Some guys are seeing a little bit higher of a spike. But i'd say thats average for the most part.
Pipeliner
the best ive seen so far is 35 with mine, edge/attitude and airaide intake
I dont think i see much over 30 unless its just a spike.
yeah, in reference to just driving around....I'm running mid to high 20's. If your asking about a spike, 36-38 is what i was talking about first. my bad
Mine will spike to 33 then pull down to 26 and hold it there.
Have not really checked for a spike but i know i can hold steady at 28-29 psi. Only messed with it on two or three settings. I slip my clutch on level 4,5 and 6 with the edge so I dont have a real max yet.
Just hooked mine up today.....Im getting 38-40 boost (in the gas)on setting 3. Is that normal or high? The warning was set to go off at 36 which is every time I get into the throttle. I since changed it to 45. Instructions dont give much info. Have fun!!!!
i only see 17-18 don't have the dpf yet
1 - 9 of 9 Posts
