I am curious as to what boost numbers I should be seeing. Going by what's in my Sig. I used one of the taps provided in the CFM intake for my boost hook up. I can see 37# with no problem about 3/4 throttle!? If I take off hard with the truck as soon as the turbo start's to spool up the tires start beaking loose ( not going up in smoke just spinning enough to hear it ) I am not saying this is a bad thing but it would not do this before I added the Boost Fooler. I wan't to make sure I am not over boosting, is 40# ok with these trucks? Between listening to the 5" no cat and the tires breaking loose I am going to wear the truck out before I get the Trans work done and the Smarty hooked up:lol3:
Any Thoughts?
I see about 42 On my 06 your fine man
Thanks, at what point do you need head studs with these trucks? With my ford I would hold my breath anytime I went over 40# I am quickly appreciating the durability of these Cumminns:thumbsup
Well thats going to be one of next purchases actually but im upgrading turbos. ATS says that they are required at anything Over 50 in one place and 45 On another.
