boost gauge is mechanical normally. I got a boost fooler for my truck. the waist gate is opening causing the boost to drop down.... My truck's boost will hit 30psi for a split second then drop to 22 psi.the 05 has the plastic capped intercoolers and i had the guy check it for leaks and we had none. the gauges are glowshift. and this may be a dumb question but how do i tell if they are mechanical or electric?
Well I may get chewed out for this but to do a little test you can vise grip the actuator hose closed. then take it for a drive and see how it reacts to the waist gate not opening. Once your done with your ride take it off and if you like it get a boost fooler..is the boost fooler the fix for it or can i do something with my wastegate so it does not open so quick?
