Alright got my injectors in yesterday, went for a test ride. All i could muster up was measly 46psi ? :confused013:
What gives ? Wastegate rod is as short as possible, and plugged the line off to try and get some more. That didn't work either, still went right to 46psi and stopped. Like its still wastegated ?? And its NOT inconsistent either, stops exactly as 46psi. Oh its a HTT 62/14 too, and my GSK isn't installed yet.
Lookin for some input:
Thanks, Brandon
42 psi ?? I cant imagine those injectors only giving me 4 psi more ! :confused013:
Banned
well if i was you, id be happy wit that.
cuz ur kinda pushin it.... i have everthing in my sig and have heat torque the head bolts and still popped the HG twice in a month
All depends on the past of the truck. The more miles the truck has, the more prone to loosing a gasket it is.
Plus how do you drive ?? If its under constant boost the h.g. will get weaker with every WOT pull.
But wow seems like im all alone on this..............:buttkick:
