My boost goes from 40-42psi WOT to 30 psi... I just took of my quadzilla boost fooler cuz it was making in between 45 to 50 psi .... i dont think it did this before i had the boost fooler... all i have is done preformance wise is a diablosport predator on the extreme RKL setting, S&B intake and 5in exshaust...Wondering if the boost drop is normal or what cuz it never did it with the boost fooler...thanks
Where are you getting your boost reading?
What RPM does it start to drop off?
If you are close to max RPM you are going to start defueling. Look at the Dyno curve on any dyno sheet, they drop off at the end.
It sounds like it is starting to defuel or a leak somewhere. I would lean toward defueling, my edge j/a would do the same thing.
im reading the psi on a auto meter gauge.... i think i figured it out it loses psi pretty high in the rpms around 2700.... i tuned i tback down to the extreme setting now.. i guess i never noticed the drop in boost before or maybe it didnt do it with the boost fooler or maybe it di d just it didnt go as low a 30psi... thanks for the info!
The load isn't as high once you're up to speed and boost will drop off. Mine does it all the time once The torque is locked and I'm passed 70mph.
If its just a quick spike with a hammer to the go-pedal then it sounds like its just a mi-nute delay in the openeing of the wastegate.
