1 - 3 of 3 Posts
i am getting ready to do my gauges and i dont understand how to hook the tubing into the back of the boost gauge. i have isspro gauges. any help will be appreciated. tia
It's a compression fitting. Put the compression nut on the male, then put the tubing in the hole. As you turn the nut to secure the tubing the tubing is compressed onto the nut. Don't over tighten. It should not pull out with a slight tug.
Hope this helps.:thumbsup
1 - 3 of 3 Posts
