i was just wondering if they are worth it?
thanks man :thumbsup:if you're running more than 44psi of boost, you need one. The only thing they're for is to prevent the ECM from setting a code when you go beyond the set boost parameters which is 40 to 44psi. The Smarty is only good up to those psi's so, you will probably need one.
yep its electronic but it still has a hose from the sender to the wastegate. a boostfooler or the mp-8 will keep the engine light from coming on.:thumbsup:isn't the waste gate on 05 and up electronic? i messed with it before and my check engine light was on for a few hours, i guess until the ecu realized everything was back in place.
ahh gotcha !yep its electronic but it still has a hose from the sender to the wastegate. a boostfooler or the mp-8 will keep the engine light from coming on.:thumbsup:
I would say no, just from my experience. Mine started malfunctioning(pegging my RP and giving me a lope at idle) so I took it off and just use the Smarty to fool. I see 65 psi with no codes.
EDIT: I was getting the same code as above along with a few others
I'll give that a shot, bofore the fooler i was hitting 40 pretty easy and since i put it on i cant get over 35lbs. :thumbsup::thumbsup: Thanks for the input.I would say no, just from my experience. Mine started malfunctioning(pegging my RP and giving me a lope at idle) so I took it off and just use the Smarty to fool. I see 65 psi with no codes.
smarty boost fools up to 40psi and i believe wont show any codes. just tells the wastegate to start opening at 40psi.oh so the smarty has a fooler built in? or it just doesn't show the code?
what are you reading your boost from? is it a mechanical or electrnic gauge? the boost fooler just tricks the computer to read 10psi lower boost so you can build that much more.I'll give that a shot, bofore the fooler i was hitting 40 pretty easy and since i put it on i cant get over 35lbs. :thumbsup::thumbsup: Thanks for the input.
Its a mechanical guage. Removed the boost fooler and cleared the DTC's, check engine light stayed off until i shut the truck off and restarted it again. Now its back on. I am still only hitting 35lbs max.what are you reading your boost from? is it a mechanical or electrnic gauge? the boost fooler just tricks the computer to read 10psi lower boost so you can build that much more.
