1 - 3 of 3 Posts
Hey guys quick question...i just installed a Edge juice w/ Attitude and a boost fooler...on LVL 3 im only seeing a max of 29-32psi of boost...is this normal cause of the fooler? i searched but couldnt find any definitive answers...thanks in advance:party018:
Mr. Vehicle Destroyer
What order did you put the boost fooler and edge in line? (if the edge takes its MAP readings after the boost fooler you are reading the fooled signal not the actual one) You may need to have a mechanical boost gauge to get actual boost numbers.
well.... i bought the edge unit used and the fooler was already installed into the harness, but i installed the fooler very last other than the egt gauge...
1 - 3 of 3 Posts
