I’ve been noticing higher temps towing grades as well. there are times I can partially blame the shift points I’ve programmed, but I suspect the wastegate is opening early and lowering boost.
While checking for boost leaks I found there was some air leakage coming from the wastegate actuator. This indicates the control solenoid has leakage and causing the wastegate to open earlier.
Also questioning if I have a partially clogged cat.
