03 5.9 Cummins six speed manual 4x4 dually... Bone stock had it about 5 years never moved the temp needle Previous one owner 90k mile from an older neighbor that passed. His wife had every recipe from day one kind of truck. He babied it and was immaculate when I purchased. Recently when pulling heavy loads over hills 12k lbs 5thwheel will get hot. My live feed gauge shows hottest 235 then I would pull over and let it rest. This happened on one trip then I took her home and changed the fan clutch with OEM and the radiator... I put in a aluminum radiator it is better but when I pulled heavy today I reached 225 never seen any thing over 205 until what ever is going on now Currently I have 190k miles, I have no oil in the water, no water in the oil and no water coming out the tale pipe, no drop in water fluid in radiator or reservoir. So I've ruled out head gasket. I have no oil in the radiator is it possible that the engine oil cooler is the culprit? If I'm pulling straight aways or empty needle never moves only steep grades while heavy... Any input would be great
