1 - 4 of 4 Posts
Does anyone make a spin-on fuel filter replacement assembly for the factory [email protected]#$%^& cannister type filter/seperator?
Thanks
Super Moderator
I got one from ebay but haven't put it on yet it looks like it should bolt right in. You could also check cummins for one. I beleive it's from a 94 dodge or else a off road engine. I'll check for a part no on it later.
Super Moderator
I have the part no. 3925600 it's for a 94 Dodge with a cummins uses a screw on filter NAPA 3402 for a screw in water/drain sensor. If you don't want the sensor in the bottom they should be able to cross it over to one with a built in drain. The mounting holes and fuel line holes look the same as my 97 CTD's.
1 - 4 of 4 Posts
