Hi all ;
had a problem last week with a bad ground on drivers side fender cause the engine to power off , fixed that but have a new issue. Ive lost all of my cab power , and underhood light , locks , windows etc etc , whats interesting is that when I key the truck to 1st stage ign or started , everything comes on fine. Check all the fuses all good , whats even stranger is this morning went out to start the truck , manually unlocked the doors and all was fixed , no idea if unlocking with the key did it , figured Id see if there were any codes as soon as I hooked up the programmer (predator) to pull the codes ,boom everything shuts off again. My local mechanic suggest a body control module , I have no idea what this is or even if the dodges have them , wonder if anyone has any ideas on what this might be , our local dealer is 2 hours away and I can only imagine the reaming Im gonna get for this kind of wiring problem . Ive also pulled both batts cables off to see if I could do a reset ?? let it sit for an hour like that , didnt do squat . Any help or suggestions guys would be really really appreciated !
thanks in advance
cheers
thatscold
thanks in advance
cheers
thatscold
