Check the head for trueness and install another MLS gasket.
If you're going to run that much timing with the meth then you need to run the 625's.
Well, it sucks, but congrats on having it hold that long. Pretty awesome truck you got there.Have about a year on my rebuild. I run the truck pretty hard, and it just started puking coolant out of the overflow. Checked waterpump, pressure cap and thermostat. All were good. Have bubbles in radiator. I did a hot retorque after I put it together and the block and head were machined. I ran a stock mls (thicker) headgasket and I blew it. I torqued my studs down to 125. So what are my best options? It is a street truck/ daily driver... should I fire ring it? I'm wondering if the combination of high timing (30 degrees) and methanol made her pop.
Thank you for any help.
At least he got a year out of his lol. I got 5 minutes out of mine
Funny
The blue should only have like 30% meth... I mix my own at 55 water and 45 meth. But I have a good source to get 5 gallons of it for $20. The timing is probably what did it. Just curious was your egts hot say 1400+?Snow told me I would be fine to run blue windshield wash so that is what I did. Too much methanol content?
