I posted about this problem a few months back, and it is still an issue.
The coupler that comes off the small turbo and links with the down tube going into the intercooler keeps blowing out. I mean a 3" hole in the side style blowout!! Last time it was on the way home and just a few miles away, so I limped it back. But this time I was 225 miles from home, but luckily 5 miles from the town we were heading. Had to get a tow for the the 5th wheel the last 5 miles, but limped the empty truck to our campsite. I next day aired a new coupler, installed it and heading on our way home. 5 miles is all this one lasted!!
It is always under heavy load, towing 14k. And it's always on a long hill at the top. I try to keep my foot regulated to 1250-1300 max egt's, and don't run over 1350.
I had a Banks intercooler, so here was my concern. While that was very sufficient when I was running a single turbo, is the compound system producing too much cfm, causing a build up of back pressure that blows the coupler on long pulls?
I had to get my wife home for work, so I had a BD Performance intercooler shipped to me and I installed it before coming home. I left my trailer at a storage facility and just got home. Obviously didn't have any problems on the way home (other than trying to keep her under 100 mph!!), she wants to run!
Any thoughts?
I don't have a gauge that accurately measures the psi, but I believe it is somewhere around 60 psi. The boots I am using are PPE.
I wish I could upload a photo, but that doesn't seem to work. It uploads and just disappears. The photos meet the requirements of pixels and resolution, but still won't upload.
This is odd. I have a banks intercooler and am also running ppe boots and have never had an issue other then the boot going onto the intake horn popping off but I figured that was an installer (my) error.
I have seen as much as 70 psi with my setup.
I’m wondering if perhaps there is a sharp edge somewhere compromising the boot or are there any odd angles that might be putting weird stress on them?
No sharp edges. It has always blown out on the passenger side.
The down tube is shaped like a shallow Z. Each time it has blown out, the turbo out and the Z tube are no longer lined up. The Z tube lifts about 1/2" to an 1". I thought it was a result of the coupler loosing integrity from the blow out. It looks lined up when it's installed.
How much flex is there with the engine?
I was looking at some photos of the original install and the blowouts. I can see in the blowouts and the build photo where the coupler has a kink in it from the tubes not lining up. I am starting to think they didn't measure the tubing properly and it's too long, causing a kink in the coupler which leads to compromised equipment.
https://lordravenblk.smugmug.com/Tubro-coupler/
I've added a link to some photos since I can't seem to post them here.
Thoughts?
