Recently did a cab swap on my 98. Kept all 98 harnesses. The problem I’ve run into is that my blower stays running with ignition off/ key removed. The blower will not operate when key is in accessory or run position. I have replaced the ignition switch, resistor, tried a different head unit for the climate controls, and tested my blower, all with no success. I have been picking through the wire harness at pdc and have been going over grounds with out very much luck. I’m sure there is something I’m missing, it would seem to me there is a short to ground somewhere. Anyone have any advice or insight? Thanks, Josh.
