So I have an issue that I’m scratching my head over, I have a 2006 2500 g56 truck, have not had an issue with this truck since I purchased it, have put around 5k miles on it, total has around 171k, changed oil right when I got it, so here’s my issue, drove it to work last week ran fine, made it less than 10 miles down the road coming home and engine started knocking real bad, shut truck down right away and had it trailer to my garage, checked oil level and it wasn’t in the dip stick, pulled filter and cut open to check for metal thinking it was a bearing, filter is clean, pulled turbo and seals are still good, drained oil and only got around 1 gallon out of the truck, I had just checked the oil two weeks ago and still had a good level. So I filled it back up new filter, started truck and it ran fine no noise at all, today tried to drive it fired up fine idea normal, as soon as I started going down the road the knock came back around 1700 rpm in 4th gear and won’t go away, I also have tons of blow by to the point the engine bay is filled with white smoke out of the crank case breather, any help of this issue or issues would be greatly appreciated.
